03-12-2009 11:28 AM
03-13-2009 03:42 AM
Dear Dennis1,
Can you specify what type of serial converter are you using? I mean what type of serial communication?
Marton
NI Hungary
03-13-2009 03:50 AM
03-17-2009 06:47 AM
The usage of general USB - serial converters are usually transparent for the user, I guess our problem is not that
Are you able to communicate with the device using the original software?
Marton
03-17-2009 08:08 AM
yes I was able to communicate with it using the original software,
but it seems very unstable, slow responding, and disconnecting all the time.
but now we moved on with another idea, just use analog outputs from labview to controll it.
It`s much more stable and faster.
07-21-2009 12:37 PM
New version of the library
version 1.1 - 20.07.2009
-Resending algorithm implemented into each command. Added RepCount terminal setting the number of attempts to perform to send the telegram
-Minor changes
11-12-2009 10:46 AM
03-21-2010 08:06 PM
hi folks,
sorry for the delay. here are the significant parameters for MM440
r0000 0
P0003 1
P0004 0
P0010 0
P0310 50.00
P0311 2815
P0700 2
P0970 0
P1000 1
P1080 0
P1082 50
P1120 5
P1121 5
P3900 0
i can add code by tomorrow, but i would first have to comment it.
cheers
flo
03-21-2010 08:20 PM
mm440 users,
here is the code. it is based on some previous version of ceties` framework with a few modifications. please check whether it does the trick for you.
good luck
flo
03-30-2010 04:10 AM
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
