03-31-2011 10:06 AM - edited 03-31-2011 10:09 AM
04-14-2010 01:57 PM
hi flo!!!
help please!!!
how I can change P2012 and P2013 in mm440 or you uss library??? becouse I have error 5008(incorrect byte count) if baud rate 9600 or error 5007(missing STX) if baud rate 38400
I have the same problem, I have changed the number of words for P2012 and P2013 and still have the same problem.
04-10-2012 04:26 PM
Hi All
thanks for the library ,... can you post it in LV 8.2 instead of 8.5 ,.. thanks jeff
04-19-2012 06:25 AM
Hello Jeff,
Please look at whole post. Zenon posted 8.2 version of library.
Kind regards,
S.P.
04-26-2012 08:44 AM
Hi All,
I am also trying to communicate micromaster 440 with labview.I have communicate micromaster with starter and everything is perfect with starter.But when i am trying to connect with labview then having error 5007 (stx missing).I have settled my baudrate at 9600.please help me to find out solution...........
05-05-2012 10:46 PM
Hello All ,..
I am trying to communicate with a 6RA70 DC control. Telegram seems ok and reads parameters just fine but when I request a change or modification to parameter I get a "cannot process request" response,.. any thoughts ??
J
05-16-2012 05:44 PM
Thanks much,.. just needed to look at the older posts,.. Like to run another issue by u ,..have communication set up with a 6RA70 and link seems ok,..if I request parameter value ,.. simoreg responds fine,.. gives me any value I ask for,.. when I request modify parameter value ( word ) or anything else simoreg responds with cannot process request, task cannot be executed,.. then it gives me a PWE of 2,.. any thoughts ,...
05-21-2012 12:48 PM
Hi All Like to run an issue by u ,..Coding in Labview I have USS communication set up with a 6RA70 and link seems ok,.. I can change parameter 51 ( allowing changing of all other parameters ). However if I try and change any other parameter like accel or decal rates,.. simoreg drive responds with "cannot process request, task cannot be executed" PWE comes back as 5 ,.. tried changing formatting ,.. no good,.. cannot change any other parameter ,...thoughts ????
05-22-2012 01:41 AM
Hi kv8vsa,
I assume you have troubles with the PKW and PZD areas in your telegram. Take a look at the following documentation from Siemens and change accordingly on your inverter so you can change Integer or float parameters in EEPROM or RAM.
http://support.automation.siemens.com/WW/view/en/5734889
If the previous document was not good enough, here you have a more comprenhensive explanation of the USS protocol:
06-14-2012 04:27 AM
Hi All,
Right now, i'm developing custom Linux board which use to collect data + control equipment.
most of these equipment using modbus protocol,
one of equipment is MM440 motor drive, using USS protocol, and I'm new to USS protocol.
because I'm in Linux environment I'm also not familiar with LabView etc.
so, does anyone ever develop library using C or C++ library of USS protocol?
or any other language which can be compiled on Linux environment?
FYI: using Debian embedded for ARM.
any help would be much appreciated
Wawan
08-01-2012 03:45 PM
wonder is you can convert USS 1.2 to LV 8.2
thx
J
