04-07-2015 05:12 PM
Dear all,
first let me tell you my system detail:
1. Hacker A100-8 brushless DC motor
2. Master spin 170 pro opto (speed controller)
3. power supply
4. NI DAQ USB-6353
I have already run this motor by using transmitter and remot control, like RC planes fly. Now I would ilke to run this motor from computer. let me give you my setup:
PC > DAQ > speed controller > motor
power supply
now I would like to use either matlab/simulink or labview, to control or run my motor in real time using generating PWM signal. can anybody help me out? Thanks in advance.
04-08-2015 12:19 PM
you'd probably get more eyes on this post if you posted it in the DAQ section since its really just about PWM. However, have you looked at the examples in LabVIEW for DAQ? There are a lot of good examples for PWM and Digital Output on DAQ devices.
Where there any particulare questions that have come up regarding your setup and how to accomplish it or are you just concerned on how to produce PWM signals in LabVIEW?
04-09-2015 04:06 AM
Hello, thanks for your reply. I am actually looking for detail about controlling this motor from LabView. How can I in real time send signal to my motor for running? I want total tutorials.
04-09-2015 08:27 AM
Since you are wanting to use DAQmx and not any of the Motion software that is made for LabVIEW the examples will be very limited. I suggest playing around with the PWM and Digital Out functions to get an understanding of how they operate.
http://www.ni.com/tutorial/2991/en/
You can also take a look at this example below which uses DAQmx to control a stepper motor. This is a little different than what your DC motor control setup will look like but it should be good for reference if you understand how stepper motors work.
https://decibel.ni.com/content/docs/DOC-6385
I still suggest posting this in the general section of the forums as it will get many more views and thats really what your application is about. This forum will get more views for things like SoftMotion which is NIs motion control software. Since you are working with DAQmx however you would want people who work more frequently with DAQmx to view your post, which will be in the general section of the forum.
