Good Evening all,
I have a stepper motor and this is successfully being controled via a driver in labview using the command language the driver responds too, so this is fine. I also have a working DAQ code (**at least should do on Monday once I can test!**) that should be recording the data from my load cell and outputting a torque value.
The next bit is the part I am not sure on:
I have two motors running at the same time currently through the same piece of code copied twice and I have a DAQ measurement reading the torques of the two motors. What I want to do is for the absolute difference in torque to be measured between the two motors and then if either motor torque is greater, slow down that motor slightly until the overall torque is zero. It doesn't need to be performed at a super high rate or speed, but I would like the system to be able to adjust thoughout the experiment.
I have a Stepper motor, driver and a NI USB 6210 DAQ.
Is this possible? Any advice on documentation to read?
Mark
