Motion Control and Motor Drives
SMD-7615 Stepper motor drive - Ethernet
Without a list of supported commands (which we don't have readily available for publishing), the only good way to figure out the proper commands is to use the Ethernet stepper in SoftMotion 2014 and use wireshark to view the commands. You can then write your TCP code in LV 2011. I realize this is not an easy task.
Message 11 of 12
(768 Views)
Thanks for the option, but may be more than I want to do. Will onsider it.
Message 12 of 12
(764 Views)
