Motion Control and Motor Drives
Reverse The Jog Of An MG17 Motor
Hello. I am using an MG17 motor to rotate a sample 180 degrees and then stop and export data. I would like to be able to do this while toggling which direction the motor rotates, but cannot figure out how to reverse the direction of the jog, and can only get it to go the same direction each time. Any help would be appreciated!
(2,440 Views)
Could you send a snippet of your code? It looks like some people use a specific toolkit for the MG17 motor. Is that what you are using? That may help determine how you can change its direction.
Madison T
(2,391 Views)
