NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
carleethian
PXI-7358 Driver Chip/Board
We're thinking of spinning our own motor driver board to interface to the PXI-7358.  I'm curious if anyone has any experience with a particular chip that interfaces well with the STEP/DIR or CW/CCW protocol.
Also, if anyone knows of any good 3rd party solutions that they decided to use I'd be interested.  I've seen this: Drive Advisor and while useful I don't feel like it's completely comprehensive.
Member
Joseph-S
Re: PXI-7358 Driver Chip/Board
Hi carleethian,
Unfortunately, I cannot recommend anything beyond the NI drives the third party drives that we sell. However, I do suggest that you look through these KnowledgeBase articles: "How Do I get the 73xx Controller and UMI-7764 to Drive a Third Party Stepper Motor?" and "How to connect the 73xx inhibit and command signal outputs to third party drives" which outline some important concepts to keep in mind when you do interface our motion controller cards with third party drives and motors. Hopefully someone in the community with more experience with 3rd party drivers can provide more insight. Feel free to post any new developments in your project.
Joseph S
Active Participant
Buechsenschuetz
I do not think that it makes much sense to design your own motor driver board, there is more to it than a plain power driver. You also need current regulation for two phases and - if you do not want to run your motor in full step mode, as I presume - intelligent control circuitry to set the phase currents.
We are using driver subsystems from IMS
They manufacture drivers in different form factors (with pin connectors, screw terminals etc) which can easily be integrated on your own pc boards as well as on panel boards. They interface easily with NI cards.
 http://www.imshome.com/index.html
 http://www.imshome.com/products/discrete_drivers.html
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
