04-08-2016 02:12 PM
I am trying to figure out how to control a servo motor with PCI7356, UMI7774 and AKD servo drives (AKD-P00306). One of NI engineer suggested to use a example VI, "three-axis vector move with position monitor.vi". However, it does not work. The motor and AKD drive work well with Workbench. Any other VIs I can start with or suggestions? Thank you in advance.
04-11-2016 11:05 AM - edited 04-11-2016 11:06 AM
Hi BasketSoccerBal
When you say it’s not working do you mean that it’s not moving your motors? Or is it throwing you errors? Also, have you set up your axes in MAX for the PCI-7356? How many axes are you planning on using? Have you been able to move the motors using the 2-D interactive in MAX?
04-18-2016 09:21 AM
I am planning to use 6-axis total, so I have 1 PCI7356, 2 UMI7774 and 6 AKD drives. Now, only 3 axes are connected. I tried '1-D interactive' in MAX and AXIS 3 has a following error. There is no error in a sample VI, but AXIS 3 is not moved at all in LanbVIEW while AXIS 1 and 2 are working. Note that AXIS 3 is working properly in Workbench.
04-19-2016 10:39 AM
Just to clarify, only your 3rd axis is not behaving as expected while working with LabVIEW and the other two are? Have you verified the wiring and did you follow this to set up your hardware:
http://www.ni.com/pdf/manuals/375543c.pdf
Additionally, have you verified that you have configured your axis correctly in NI-MAX?
04-19-2016 11:27 AM
Yes, I did set up as that manual. Any other configurations required in NI MAX more than as described in that manual?
One problem was the cable between UMI7774 and AKD drive. With a new cable, all 3 axes are controllable. However, the 'following error' occurs randomly in NI MAX interactive.
04-20-2016 05:25 PM
What do you mean by randomly? Is it only when you're commanding a move in the interactive test panel? Have you tried running any LabVIEW examples?
04-21-2016 07:24 AM
I meant that some days the following errror occurs and some days do not with the same set up in NI MAX. I tried a sample VI and no error occurs so far.
Does NI provide any other docs for the set up ?
04-21-2016 01:24 PM
Here is the getting started guide for NI-Motion and the 73XX cards:
Getting Started with NI-Motion for NI 73xx Motion Controllers
http://www.ni.com/pdf/manuals/373329e.pdf
Additionally, here is a KB on following errors that you may find useful:
Following Error in a Motion Control System
http://digital.ni.com/public.nsf/allkb/899AE29CB4E3578B8625709D0070A725?OpenDocument
