07-12-2012 12:51 PM
I have a P70360 Stepper Driver connected to a NI Stepper Motor. When I connect it to power, a green status light turns on. I would like to configure the driver using the software rather than the DIP switches. I tried the DIP switches and it flashed red.
I downloaded the P7000 GUI/Firmware from the CD that came with the driver. I connected the driver to the computer using a serial connector. I setup the COM1 settings with the settings from the manual.
When I pull up the P7000 Tools, it can not find the driver.
How do I configure the driver? If I have to use the DIP switches, how do I connect them correctly?
07-13-2012 04:31 PM
Hi have you seen this document about getting started with the P7000? http://www.ni.com/pdf/manuals/372324c.pdf
07-16-2012 08:48 AM
Yes I have seen that manual. It didn't solve the problem.
It has the below on my problem.
The P7000 Tools configuration software does not detect the drive.
Verify that the drive is connected to the COM1 port on the computer.
Verify that the COM1 port settings are correct as described in Step 4: Configuring the P7000 Drive with the Serial Port (Optional).
Power is not properly connected. Verify that the green LED is on.
I have verified those things.
07-17-2012 05:10 PM
A few other things we can try -
Windows sometimes uses up COM1, have you tried using a different COM port?
Have you tested using a different serial cable?
Page 18 of this manual shows how to configure the dip switches - http://www.ni.com/pdf/manuals/P7000AC___Revision_F
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
