07-21-2015 01:48 AM
I have a stepper motor (ARM69AK) and controller ARD-KD.
Does anyone have a Labview driver for this controller or sample code.
I want to use RS485 to control it.
I downloaded and installed modbus Labview Library.
thanks in advance
09-11-2015 04:16 AM
I have the same Question : ) I have looked for the Labview library for this motor driver for a while, bus got nothing : (
09-14-2015 03:48 AM
Hi Skydubin,
I didn't found any driver for Oriental Motor.
Finally, I developped my program with Modbus driver from DSC module
read, write and the adress of the register...
09-14-2015 11:35 AM
Hi Minikisscool,
it is great !! You have succesafully developped you program . : )
You said you developped your program with Modbus driver from DSC module.
http://www.ni.com/labview/labviewdsc/d/ is it ?
You have download this LabVIEW DSC to develop you programm?
Or you just use the modbus Labview Library? Last week i get the Motor and Driver and i am really new in Labview : (
I would be very thankful if you could send me the Labview Programm Code : )
09-14-2015 11:37 AM
My Email : rising1sun1@hotmail.com
thanks in advance
09-14-2015 11:47 AM
in fact, I found 3 version of Modbus Library
MODBUS Library for LabVIEW Version 1.21
http://www.ni.com/example/29756/en/
LabVIEW Modbus API v1.1.3.32
https://decibel.ni.com/content/docs/DOC-30140
MODBUS included in DSC module for LV2014
http://zone.ni.com/reference/en-XX/help/370622M-01
I already made a development with 1.21 from NI.
My program works with RS485 through COM port. (Computer to device)
I don't devellop a full correct driver, but I have a code witch read a lot of usefull register and an other with Read / Write
09-15-2015 02:37 AM
thanks a lot for your useful information : ) i think i can work further on it.
09-15-2015 03:06 AM
I attached 3 files
1 for NI modbus driver and 2 for DSC driver
I hope, it will help you.
For me, it was not so easy to works with material from Oriental Motor. It should be the last time.
I don't recommend theses produts, No Labview driver, no support (phone, mail or forum)
09-15-2015 03:07 AM
Two others usefull program
09-15-2015 04:01 AM
Thank you very much.
And you are absolutly right !! It is really hard to work with Oriental Motor. : (
