02-16-2017 11:15 AM
I am using an ESP301 Motion Controller and two stages UTM50CC1HL from Newport.
09-09-2018 09:42 AM
Hi
I just started learning to control ESP301 with Labview, and now I have several problems:
1 I can't find a USB device in NI MAX. (USB driver is already installed)
2 The subVI is missing when I open the example.
I hope that you can help me solve these problems.
Thank you very much!
09-13-2018 07:05 PM
Hi John,
Just some time while on your journey to get it all right:
1) You don't need to put File I/O function within while loop as it could potentially execute on every execution of while loop unless while loop is set to terminate upon completion of first execution.
2) Check out if you need IVI driver. I have always used NI USB devices and they appear up on NI DAQ mx as 'Dev' but when I used third party serial com device recently, I had to install IVI drivers recently.
3) You really have to create your first vi out of example program. Often once you have installed driver, a new pallete appears with controller vis and a full sample project that you could just open into a block diagram and Hurray! Its all done for you.
See if you can use manufacturer's project to control your two axis first. Hope it helps.
