I would like to control the position of servo motor with a myRIO. Specifically, I would like to move the motor through a trajectory. What is the best way to do this?
Here is how I am currently doing it (below, and code attached), using a myRIO. Two independent while loops are running. The top one reads a *.txt file called Trajectory.txt (on the myRIO), which contains a column vector with positions at which I'd like the motor to move. Currently, Trajectory.txt is a sinusoid of amplitude 1 and period 1000 samples. Each time the loop runs, it loads the next entry in Trajectory.txt and sends the value to the DesiredPosition variable.
The second while loop reads the DesiredPosition variable, compares it to the encoder-measured position, performs PID control on the resulting error, then sends the signal to my motor's amplifier via an analog output.
My motor executes the trajectory, but the motion is extremely rough. I can feel and hear the shaft vibrate as each new position is loaded. Although I would like the top while loop to run at 1kHz, it seems that it can't run faster than 53Hz. If I could run it faster, my motor could probably low-pass filter the signal and the motion would be smoother. Would anyone suggest a better strategy?
Matthew
