04-07-2017 04:45 PM
Solved! Go to Solution.
04-10-2017 01:13 PM
Hello spatan2,
It depends on how your arm kit and controller interface with a computer as there are many ways to communicate between National Instruments hardware and software and third party instrumentation.
I tried to see if we had any existing documentation on using LabVIEW with your Robotic Arm, and I found an existing forum post about a similar question. This forum may answer some of your questions on using the arm robot with LabVIEW.
There was also a similar question asked on the RobotShop forums, and it looks like you can communicate with the servo using serial communication through VISA commands in LabVIEW.
Hannah
Applications Engineering
04-11-2017 02:36 PM
04-14-2017 12:53 PM
Hannah,
Just an update - I did end up using Arduino with labVIEW, and was able to move the servo - However, the LIFA apparently is archived. Its LINX now.
Spatan2
