04-04-2016 01:26 PM
Thanks!
These examples seem a lot like what I've attempted (with the exception of the "=" in the command).
BTW, it was very strange that initially the encoder seemed to completely ignore what was sent from LabVIEW, even though the TCP packets were seemingly the same as those sent by Lexium, but then I realized that the open socket that Lexium was keeping, blocked all other communications with the encoder, and no commands came through. Conclusion: CLOSE LEXIUM AS SOON AS YOU FINISHED CONFIGURING THE CONNECTION PARAMETERS.
I even managed to get it working through MATLAB 🙂
03-17-2017 04:15 AM - edited 03-17-2017 04:18 AM
Hello Staller,
could you maybe upload your VI for me? I have no problems connecting to the drive with the schneider Mcode example. I can write and read almost anything. But I have some problems reading the counter beyond 10000 steps. From 0-9999 it shows everything correctly but as soon as I have a position beyond 10000 the indicator is blinking and showing different results for the current position.
BTW: I also connect with TCP/IP without any VISA
03-17-2017 08:14 AM
I cannot share my individual VI unfortunately. I handed the project off to another person over a year ago and I think its still in development. I can say that in the original version, we used the range of -6300 to 6300 steps in routine operations but not up to 10000 steps. You may need to contact the company and ask about the counter.
07-11-2017 07:29 PM
Thanks you all. Below is one my problem which I met for MDrive23plus SEM. The model is MDI1PRD23C7-EQ.
I set up connection through USB to 485 cables between the motor and PC. Problem is that I can't see command symbol in terminal window (PC side). Thus I can't send commend to motor through that window.
I have tried PD, but no response. The hot key Ctrl+C can get some response from Motor.
The P1 and P2 interfaces are connected. The device manager in PC can see the USB to 485 cable.
It is strange and the motor can't run. I have tried different paud rates via manual set and also by automatic detect.
Anyone can hint me? Thanks.
07-12-2017 05:57 PM
Hi hufeibupt, I would recommend starting another post under the Motion forums, since the original question has been answered and you would get more visibility for your question. It would also be helpful to attach a screenshot of what you're seeing.
Angela L.
07-12-2017 06:18 PM
Hi Angela L.
ok. Fine and thanks. // Hufeibupt.
