06-19-2008 08:34 AM
06-19-2008 06:34 PM
Hi Eric,
I have used the Compax-3’s with NI-motion cards (7358). It works fine if you set the compax in torque mode and direct pass-through of encoder signals. Make sure you enable the amplifier or it’s output stage with the NI controllers enable output else things may go flying in my experience! I expect other configurations will work but this is how I set mine up. Personally I would use the NI card with a UMI and not the ACR, but I suppose it depends upon your application and the cost comparison.
Good luck.
-Martin
06-21-2008 05:22 PM
07-16-2008 05:52 PM
Yet another motion control / activeX n00b here! I've inherited code that works, but neither smoothly nor fast. What confuses me is that new ITerminal and IStatus nodes have empty pick lists, even when I connect them to the ref wire. If have to copy existing nodes that show the properties I'm interested in. How would one create a motion control vi from scratch?
Also, has anyone found a document listing the meaning of the various text strings that can be sent to the ACR (see attached screen shot)?
Finally, where did my BOXBRIDGELib.ITerminal and .IStatus objects come from? I can't find them in any library.
Unlike most things LabVIEW, I'm finding this not at all intuitive.
Jeff
05-14-2013 11:25 PM
Hi Jeff,
Parker now has a solution. BTW is this post still active? I've a few troubles with this labview file...
Link to file...
http://www.parkermotion.com/support_samples.htm
File name : LabView example, under the ComACRserver 6.x (installed with ACR View 6.x) sub category of PC Program Samples for ACR9xxx and Aries Controller category.
-Vijay.
05-15-2013 09:40 AM
Be careful when using the Parker provided examples. They were written by someone that was familiar with the ACR product line, but not LabVIEW. I only used them for reference, and created my own VI's.
03-27-2017 07:20 AM
i want to use acr9640 controller through labview ? i am unable to do it, could anyone please help ?
01-22-2020 09:28 AM
Parker ACR7000 is a new controller that is supposed to be compatible with the ACR9000 series. I'm also looking for a useful LabVIEW driver and not finding much but Parker's simple Labview example. I think they are still using "ComACRServer.exe, a 32-bit OLE automation server". Please post if you know of one.
01-28-2020 11:10 AM
Here are some VI's that I made. I am sure I have full projects but will have to look for them.
01-28-2020 11:41 AM
Thanks. It is appreciated.
