Kollmorgen AKD problem of enable
Hi ,
    i try to use the Kollmorgen driver AKD-P00606 with motor AKM32H
I don t know have to enable the hardware . I try to use WorkBench but only i juste enable the software .
How can i do please to enable the hardware with WorkBench ?
(7,057 Views)
Accepted by topic author k-usa
You cannot hardware enable the drive from WorkBench. The hardware enable pin is X8/4 and it must be powered in order for the drive to be hardware enabled. See page 134 of the installation guide for more information.
(7,037 Views)
Hi Paul ,
    i found the problem, i did not connect the X8-3 but only the X8-4 .
but now it run
thank you
(7,035 Views)
What did you use to power the STO?  I have seen in the drawings to connect it to X1/3 or to give 24VDC+.  May I ask what you have connected to X8/3 & 4??
(3,506 Views)
