Isel imc-p1-4
i am currently working with a traversing system to survey a required volume and make experiments. I use an isel imc-p1-4 as my control unit to establish connection between my computer and my traversing system, at DNC mode.
I used to work with another traversing system and all my operations did work. Today, I have changed traverse, setting all the necessary parameters, and some operations can be carried out like referencing, while sending manual commands doesn't work at all: the VISA gets through the writing function and it seems like it doesn't read it, as my machine is not moving.
Can anyone help me with this huge problem?
(4,187 Views)
did you find out the solution for your problem?
(2,106 Views)
