01-18-2014 03:10 PM
I have an application that loads a named custom 7358 motion controller configuration during startup. I've installed the app and run it on 15+ different computers with a 7358 and it has worked great. Recently I installed the app on a pc with a 7354 motion controller, and when I started the app I received an error saying the initialization settings cannot be found. Furthermore, when I use MAX to try and choose my custom settings through the "Change Settings..." dialog box, my custom configuration does not show up. I know my configuration is in the MAX database--when I import it into MAX I receive a warning the configuration already exists.
Does the MAX database automatically prevent me from taking a configuration exported from a 7358 and applying it to a 7354?
01-20-2014 01:13 PM
I'm sorry but I do not believe that you will be able to transfer the configuration settings from a 7358 to a 7354. If fact, I don't believe that you can transfer the configuration setting from one card model to another. MAX will only allow a configuration setting upload from a file that matches the model of the device. This is done because the different devices have different configuration options, number of axes, different firmware, etc.
I believe that you will have to make a new configuration file for every device that you plan on using.
Jeremy P.
01-20-2014 01:20 PM
Thanks Jeremy. That's what I figured, but I wanted to verify that before telling my customer.
01-21-2014 10:12 AM
Best wishes.
Jeremy P
09-01-2014 10:16 AM
I'm having a very similar problem. Is there at least a way I can open the 7358 settings to view them? I don't have an 8 axes card that I can load them on to, just or view them.
09-02-2014 05:30 PM
I'm not sure if there's a way to do that. I haven't been able to find anything by searching around.
What happens when you attempt to import your MAX Configuration that contains the 7358 settings?
-Mike
09-03-2014 03:38 AM
Nothing, doesn't even give you an error message stating that it failed, they just don't show up in the list of settings you can select.
09-03-2014 03:18 PM
