09-05-2016 06:08 AM
have to set up a system that uses the following Kollmorgen components:
Servomotor AKM24D-ANBNR-00
Drive AKD-P00306-NBCC-E000
Motor (AKM13C-AKCNGD00)
I am interested in creating with LabVIEW an application to control the motor by sending a speed profile. I read that NI has very expensive software to communicate with these drives. So I want to use a solution with a PC and modbus (via ethernet cable) communication method.
The only code that works to communicate with the drive is attached. I can read the "588" parameter and get the position of the motor. I went through the parameter list and they have 1760 instructions but I have no idea which one can make it move (write) hence I have no way of sending motion profiles!!! Any suggestions? Does anyone have a basic code to make the motor move???
09-06-2016 01:31 PM
Anon,
I see you received an answer to your question here: http://forums.ni.com/t5/LabVIEW/Kollmorgen-AKD-communication-with-Labview-Ethernet-IP-drivers/td-p/2...
Do you still need help?
09-07-2016 12:47 AM
Thank you for your reply!
Yes, I do need help as I have specific hardware to work on.
I need to find a way to send instructions to the AKD drive, and more importantly the sequence of the instructions in order to make it move. I have a list via Kollmorgen with prameters & their registered addresses but I am not sure about the sequence to use and what to fill the registers! Its not as simple as just write a value like DAQmx and this is the first time I use Modbus.
Hence if you have an example it will be very helpfull!!!
It would also be nice to have the sequence to start/control the motion tasks.
Thank you in advance
09-08-2016 10:53 AM
Anon,
I would recommend contacting Kollmorgen to find out more about the sequence; they may know more about this subject than what you'll find on NI forums.
09-13-2016 12:20 AM
Thank you for the reply.
Unfortunatelly Kollmorgen replied (through te local dealership) that they dont offer support for Labview applications. Propably since they teamed with NI to create a suite that you pay to get, they dont offer free help.
If anyone even has experience calling and stopping the preprogrammed motion tasks please let me know
09-13-2016 05:03 PM
I saw you mentioned Modbus in your initial post, are you looking for a way to do this using the Modbus library for LabVIEW?
A good option for you might be SoftMotion Lite. This is a free version of SoftMotion that you can use to implement straight line movements. You can check if SoftMotion Lite will work for your application on this LabVIEW SoftMotion Selection Guide.
