11-26-2014 06:30 PM
Hi
I am looking a simple example to set or read paramaters of AKD driver with Labview .
The AKD has ethernet communication and the control is analogue - AKD-P00306-NBAN-0000
I want to use Labview to read the same paramerters like Kollmorgen WorkBench
Thank you for you help
12-02-2014 01:17 PM
Hi k-usa,
We use Workbench to access these parameters, and unfortunately for many of them there isn't a way to access them in LabVIEW. The manual for using the AKD with our C-Series modules (http://www.ni.com/pdf/manuals/375516b.pdf) specifies setting these parameters in Workbench for this reason. I apologize that there isn't a way to access many of them in LabVIEW.
12-02-2014 03:33 PM
Hi thank your for your help
i just find a solution with TELNET protocol
12-02-2014 03:39 PM
Hi k-usa,
Interesting! What is the solution you found?
12-02-2014 04:04 PM
I use the telenet protocol with Labview API :
