08-31-2015 04:56 AM
I am using a Kollmorgen AKD drive (model: AKD-P00306-NAAN-0000) and it keeps showing a DC bus undervoltage error (sometimes after a very quick F302 motor overheat error, even when the motor does not run). I have checked the power supply to the drive from the internal converter and it is 24VDC like it should be.
Any suggestions as to what I could do?
i have attached a few images below to help.
08-31-2015 06:06 AM
DC Bus refers to the DC section of the drive after rectification of the AC input. Usually means your AC input is absent or low. What is your input voltage?
08-31-2015 06:41 AM
08-31-2015 07:00 AM
I am not sure where you are reading the 24DVC. That is logic voltage, not bus voltage. Bus voltage should be about 340VDC. What power supply are you talking about?
08-31-2015 07:14 AM
08-31-2015 07:16 AM
Please look at the manual and make the power connections accordingly.
