11-11-2014 03:23 PM
I have a stage with an encoder resolution of 2048 cts/rev and gear ratio of 28.4:1. How do I calculate the distance traveled in millimeters?
Ifenna
11-11-2014 03:34 PM
Not enough information. What kind of stage? Screw? Belt? You need to know the distance your stage moves based on an input of 1 revolution.
11-17-2014 09:52 AM - edited 11-17-2014 09:53 AM
Hi
We need to know the Diameter(D) of your wheel ( for rotary encoder )
1 round = 2048 ct =Pi x D = 360 deg
example : if D= 200 mili-meters ==> 2048 ct =3.14*200=628 mm
Then you resolution is Resolution (mm)= (628*1)/2048 =0.307 mm This meam : 1 count of your encoder you do 0.307 mm a travel
ANd now you multiply by the racio of you gear
11-19-2014 09:36 AM
The only additional information I have is Drive screw pitch which is 0.4mm/rev. I this the distance traveled in one reveoluton?
11-19-2014 10:03 AM
Do you have schematic or draw ?
11-21-2014 06:38 AM
Distance(mm)=2048*28.4/0.4
