12-09-2014 01:30 PM
I never used Lab View before. For a project, we have to use Lab View to make a small dc motor (HP:1/2, RPM 1725) start, and stop. I have no idea how to do this. Any advice/help anyone? Any tutorial or vi. would help!
12-10-2014 11:32 AM - edited 12-10-2014 11:32 AM
Hi there,
Search for “H-bridge” for a common DC motor control circuit, the input terminals from the bridge can be controlled using any DAQ device with digital output lines from LabVIEW. For example: https://decibel.ni.com/content/docs/DOC-17062
12-10-2014 07:29 PM
I would not recommend using that circuit for controlling a 1/2HP motor. Just buy a DC drive, and use a USB DAQ that has relays or digital outputs to control the digital inputs of the drive.
12-11-2014 08:55 AM
Thanks! But what's the difference between a DC drive and a labjak with relay? I just need to control the power and speed of the motor.
03-02-2017 11:13 PM
hello sir I have a problem like I am using a stepper motor driver module (Rhino) and it controlling the motor. Initially stepper is running without running the code, if I run the code it will come to control. I am using DAQ usb 6009.
03-03-2017 11:52 AM
Hi Xanthrone,
This thread has been inactive for almost three years now, so you would probably have better luck getting your question noticed if you were to post a new thread on the discussion forums. When you do, could you be more specific about "come to control?"
