02-18-2014 10:07 AM
I'm using the NI9512 with a stepper with integrated drive
When I try to deploy, first I get:
"One or more I/O Drivers on the target require Active mode to access I/O through the NI Scan Engine. If you choose to switch to Active mode, the NI Scan Engine will automatically transition to Active mode after the operation has completed successfully. Note: The mode change does not apply to local I/O."
When I press "apply" I get:
Initializing... Calculating dependencies... Checking items for conflicts. This operation could take a while... Preparing items for download. This operation could take a while... Deploying NI-cRIO-9074-013A59E2(successfully deployed target settings) Deploying Untitled Project 2 Deploying Axis 1 NI SoftMotion: An internal software error has occurred. Please contact National Instruments for assistance. Deployment completed with errors"
any ideas?
08-13-2019 12:51 PM
...5 years later, same problem here (no solution)
