Hello Viper,
Unfortunately there is not direct way to connect our motion hardware with your current Opto-G4 Rack.
You can see a knowledge base article about motion cabling here:
http://digital.ni.com/public.nsf/allkb/5BCA4D4A31025542862573BF0057750AEssentially, the PCI 7332 has a 68pin output that can connect directly to our Motion drivers or UMI's using the
SHC68-C68-S cable
The other cabling option is the
SH68-C68-S that has one of our VHDCI connectors on one end and a 0.05 68-pin SCSI D-type connector on the other that can be used to interface with some 3rd party devices.
The UMI is just a breakout box that has 68 screw terminals that map to the 68 pins output from the PCI card. You can also make a custom cable. We offer the
SHC68-NT-S Shielded Cable Assembly (unterminated) which has our 68pin connector on one end, and open ended wires on the other which you can put your own connector on.
Hope this helps!
Rishi L
