Ansari,
The Kollmorgen AKM servo motors are available with several different connector types, but the ones that NI sells will have the double rotating connectors that work with the AKM to AKD cablesets. The power cable is already split to bare wires, but the feedback connector is a D-sub connector that would need to be stripped to be used with a third party drive with a different connector. The connectors are Kollmorgen specific, so you would need to purchase the corresponding cableset to the motor.
I would highly recommend using an AKD drive with these motors, as they offer the best plug and play operation with the motor and with any of our motor controllers. Kollmorgen may have bare wire cable sets for the AKM motors, but the best solution will be to pair the motors with an AKD drive.
