Tom:
Your response is much appreciated.
Initially, I had no timeout specified, and it defaulted to 25,000 ms (25 seconds). 25 seconds went by, and it timed out. The scan I'm doing completes in less than 100 ms, so timeout length is not a factor.
The problem has to be
1) I'm doing something wrong in LabVIEW, or
2) I'm not sending the right commands to the 3706A.
An apps engineer at NI told me my LabVIEW code looks correct. In fact, I'm following an example of SRQ I got from the NI website.
I'm working with Keithley to see if my commands are correct. This is the most likely thing causing the trouble. I downloaded Keithely's LabVIEW driver for the 3706A. There's tons of code that do different things, but unfortunately, SRQ is not one of them.
Thanks again.
