Place an XY graph on a vi and setup a y axis to include regular and minor grid lines. If you resize the graph you will see that the major grids and markers behave properly but the minor ones will change and you will either have more or fewer minor grids depending on if you made the graph larger or smaller. Only way I found to get grids back to how they were originally is to reset BOTH the yaxis increment and minor increment. I talked to tech support this morning and it was definitely able to be reproduced on their end and viewed as a bug which will be fed into the CAR process. Just wanted to post in case others run into this too
