NI Home
Cart Cart | Help
You are here:
Reply
Member ldo
Member
ldo
setting Z Order of measurement studio controls in Visual C++
How can I set the Z Order of a measurement studio control (such as a button, numeric edit, etc.) from within a VC 6.0 application? I have several overlapping controls in which the first control is on top and the controls I apply later are below. I must go through all kinds of gyrations to control the Z Order.
Active Participant
Chris Matthews
Re: setting Z Order of measurement studio controls in Visual C++
Tab order in Visual C++ dialogs controls Z-plane order. You can set the tab order under Layout->Tab Order. The lower the number in the tab order, the higher on the Z-plane.
Best Regards,
Chris Matthews
Member ldo
Member
ldo
Thank you, Chris. I finally found that tab order equates to Z-order under Visual C++. Microsoft could do a lot to improve their help command search capabilities.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
