08-07-2014 01:28 AM - edited 08-07-2014 01:30 AM
Hello
i write a little programm. with this programm i like to read continuous samples from my NI 6251 with 1MHZ. I works okay, but every 3000 samples it is not continuous and i lost 0,010ms. I think think i not good to initialised the task every 3000 samples, but i have found no other solution that is working for me.
Need i a callback funtion to do this or need i on external clock to do this correct..
Here is mylittle porgramm.
#include<stdio.h> #include<NIDAQmx.h> #define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else int main(void) { int32 error=0; TaskHandle taskHandle=0; int32 read; float64 data[3000]; char errBuff[4096]={'\0'}; float64 spannung1[3000]; int32 start = 0; int i; DAQmxErrChk (DAQmxCreateTask("",&taskHandle)); DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","",DAQmx_Val_Diff,-10.0,10.0,DAQmx_Val_Volts,NULL)); DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1000000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,3000)); for (start=0;start<1000;start++) { DAQmxErrChk (DAQmxStartTask(taskHandle)); DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,3000,10.0,DAQmx_Val_GroupByChannel,data,3000,&read,NULL)); for(i=0; i<3000; i++) { spannung1[i]=data[i]; printf("Zahl %d %d %f\n",start,i, spannung1[i]); } DAQmxStopTask(taskHandle); } Error: if( DAQmxFailed(error) ) DAQmxGetExtendedErrorInfo(errBuff,2048); if( taskHandle!=0 ) { DAQmxStopTask(taskHandle); DAQmxClearTask(taskHandle); } if( DAQmxFailed(error) ) printf("DAQmx Error: %s\n",errBuff); printf("End of program, press Enter key to quit\n"); getchar(); return 0; }
thanks for helping me.
08-07-2014 03:06 PM
ich had solve my problem with a callback funktion.
