NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
vijay82
linking errors while building C examples in VC 6.0
I am using NI PCI5112 DIGITIZER CARD  with NISCOPE 3.6 on WIDOWS XP OS. I am trying to build the c examples that are supplied along with the driver software in VC++ 6.0. I have included the header files in the following folders,
D:\Program Files\IVI Foundation\IVI\Include
D:\Program Files\IVI Foundation\VISA\WinNT\include
D:\Documents and Settings\All Users\Documents\National Instruments\NI-SCOPE\examples\c\common
I have also included the library files in the following folders:
D:\Program Files\IVI Foundation\VISA\WinNT\lib
D:\PROGRAM FILES\IVI FOUNDATION\IVI\LIB
Whenever I am trying to build any example c source code, I encounter the following linking error.
--------------------Configuration: vijay1 - Win32 Debug--------------------
Linking...
MultiRecord.obj : error LNK2001: unresolved external symbol _niScope_GenericMultiRecord@0
MultiRecord.obj : error LNK2001: unresolved external symbol _asciiPlot@8
Debug/vijay1.exe : fatal error LNK1120: 2 unresolved externals
Error executing link.exe.
vijay1.exe - 3 error(s), 0 warning(s)
you are kindly requested to extend your guidance in resolving this problem.
Member
蔚蓝的天1280
回复: linking errors while building C examples in VC 6.0
I have encountered a simila problem.
I call IVI CLASS Driver-functions in VC6.0 without no compiling errors.Howerer,there is a fatal,unknown link-error,
I include the same .h files and .lib files.
In my opinion,you should include revalent ni-files.
Active Participant
D_Biel
Try adding the appropriate source files from C:\Users\Public\Documents\National Instruments\NI-SCOPE\examples\c\common. With the errors posted by vijay, I would suggest adding asciiplot.c and GenericMultiRecord.c.
Product Support Engineer
Member
蔚蓝的天1280
Thanks very much!
But there is a problem that I didn't explain in details.
My Test programs is that I call DMM IVI-CLASS Drivers in VC 6.0. However, there is a fatal error LINK1000:unknown
error.
Can you help me solve it?
The contrete problem IN the Attachment.
Thanks again!
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
