Measurement Studio for VC++
linking errors while building C examples in VC 6.0
I am using NI PCI5112 DIGITIZER CARD  with NISCOPE 3.6 on WIDOWS XP OS. I am trying to build the c examples that are supplied along with the driver software in VC++ 6.0. I have included the header files in the following folders,
D:\Program Files\IVI Foundation\IVI\Include
D:\Program Files\IVI Foundation\VISA\WinNT\include
D:\Documents and Settings\All Users\Documents\National Instruments\NI-SCOPE\examples\c\common
I have also included the library files in the following folders:
D:\Program Files\IVI Foundation\VISA\WinNT\lib
D:\PROGRAM FILES\IVI FOUNDATION\IVI\LIB
Whenever I am trying to build any example c source code, I encounter the following linking error.
--------------------Configuration: vijay1 - Win32 Debug--------------------
Linking...
MultiRecord.obj : error LNK2001: unresolved external symbol _niScope_GenericMultiRecord@0
MultiRecord.obj : error LNK2001: unresolved external symbol _asciiPlot@8
Debug/vijay1.exe : fatal error LNK1120: 2 unresolved externals
Error executing link.exe.
vijay1.exe - 3 error(s), 0 warning(s)
you are kindly requested to extend your guidance in resolving this problem.
(5,646 Views)
I have encountered a simila problem.
I call IVI CLASS Driver-functions in VC6.0 without no compiling errors.Howerer,there is a fatal,unknown link-error,
I include the same .h files and .lib files.
In my opinion,you should include revalent ni-files.
(5,581 Views)
Try adding the appropriate source files from C:\Users\Public\Documents\National Instruments\NI-SCOPE\examples\c\common. With the errors posted by vijay, I would suggest adding asciiplot.c and GenericMultiRecord.c.
(5,577 Views)
Thanks very much!
But there is a problem that I didn't explain in details.
My Test programs is that I call DMM IVI-CLASS Drivers in VC 6.0. However, there is a fatal error LINK1000:unknown
error.
Can you help me solve it?
The contrete problem IN the Attachment.
Thanks again!
(5,572 Views)
