Greetings,
Did you place the event on the FP-2000 channel in VC++? If the application is set up to handle the event in a certain way, it will be a matter of modifying the application to ignore the event. If you could give more details about how you have installed the event, maybe another solution could be presented. Thanks and good luck.
