In the VisualC examples directory I pointed you to, you will find both a .MAK file and a .C file for each example. The .MAK file is a makefile for a Visual C project. This makefile can be loaded into versions of Visual Studio prior to version 6.0, or converted into a project file that is compatible with version 6.0. If you open up the makefile you will find that certain NI-DAQ driver libraries and header files are necessary.
Specifically, you will need to include the nidex32.lib and nidaq32.lib library files.
Justin Britten
