Les,
(2) Not quite true. Although your application resides on the development machine, the code will be loaded and run on the remote machine. This means that when that code requests to use services provided by an NI-DAQ DLL, it will attempt to locate and load that DLL on the remote machine. Installing an instrument driver requires more than just having the DLL present. The operating system on the remote machine needs to know about the DLL and what services it provides (i.e. the DLL must be registered, something the NI-DAQ installer does for you), plus most hardware requires other supporting files or device drivers to be present. You need to install the NI-DAQ driver (free of charge) on any machine that has NI data acquisition hardware instal
led in it, whether you are running local or remote applications.
TonyH
Measurement Studio
NI
