Measurement Studio for VC++
Synchronize the clock of pxi ni5112
There are 4 PXI NI5112 in my system.I call the function niScope_InitiateAcquisition() for each NI5112 in sequence and I found that there are a time difference of 70 msecs among each NI5112.
1.How can I avoid this time difference?
2.How can I let the clock of each NI5112 start at the same time?
(2,861 Views)
There is an example that ships with NI-Scope which shows how to synchronize 2 PXI-5112s together. One is configured as a master and the other as a slave. For more info, read the readme.txt which is included with the example. Here is the path to where the example is:
C:\VXIpnp\WinNT\NISCOPE\Examples\c\MStudioC++\5112Sync
Jack Arnold
Application Engineer
(2,861 Views)
Thank you!
I have tried this example several time and I found that there is a time difference (about 70 ms) in the triger time between the master and the slave.Have you ever tested this example?
(2,861 Views)
