Measurement Studio for VC++
Reading TDM files in VS2013, C++
I am trying to use the TDM C DLL files created by NI to read and write TDM/TDX files in a C++ program in VS.
When I try and build the code calling functions in nilibddc.h, I get LNK2019 errors, saying there is an unresolved external symbol. I am not sure of the proper method to set up a link between my cpp and the lib file I am trying to call. Any advice would be appreciated.
Also trying to determine if there is a way to get TDM/TDX data editing on Cygwin instead of VS.
Thanks!
(4,495 Views)
Have you seen these resources for your specific error/issue?
http://digital.ni.com/public.nsf/allkb/A3663DE39D6A2C5A86257204005C11CA
http://www.ni.com/white-paper/3341/en/#toc9
http://www.ni.com/white-paper/2824/en/
http://forums.ni.com/t5/DIAdem/Linking-error-when-using-C-DLL-for-writing-TDM-files/td-p/1112024
Please let me know if these links are useful.
Jonathan R.
Applications Engineer
(4,465 Views)
Actually you need two libs to be added
  • nilibddc.lib
  • user32.lib
that should resolve everything needed.
If you put the following lines into a batch file stored in the samples folder of the ddc lib you can compile the samples by just dragging the c file on the batch. VS140COMNTools has to be adjusted to the installed Visual studio version.
64 bit Visual Studio 2015 (Visual C 14) example:
@ECHO OFF
if EXIST "%VS140COMNTOOLS%\..\..\VC\bin\amd64\vcvars64.bat" (
  call "%VS140COMNTOOLS%\..\..\VC\bin\amd64\vcvars64.bat" > NUL
cl %1 /I "%~dp0..\dev\include" /DLL "%~dp0..\dev\lib\64-bit\msvc64\nilibddc.lib" user32.lib /Fe"%~dp0..\dev\bin\64-bit\%~n1.exe"
If NOT %ERRORLEVEL% == 0 (
  echo ERRO occured
  pause
  goto LEAVE
:LEAVE
32 bit Visual Studio 2010 (Visual C 10) example:
@ECHO OFF
if EXIST "%VS100COMNTOOLS%\vsvars32.bat" (
  call "%VS100COMNTOOLS%\vsvars32.bat"
cl %1 /I "%~dp0..\dev\include" /DLL "%~dp0..\dev\lib\32-bit\msvc\nilibddc.lib" user32.lib /Fe"%~dp0..\dev\bin\32-bit\%~n1.exe"
  echo ERRO occured
  pause
  goto LEAVE
:LEAVE
(4,460 Views)
