Measurement Studio for VC++
Question about the Signal Processing Toolkit
I am using Measurement Studio with Visual C++ 6. Is it possible to use the
Signal Processing Toolkit in this environment or does LabWindowsCVI have to
be used? Would the toolkit supply a lib/dll that could be linked into a
VC++ project and called directly from the program?
(2,890 Views)
The signal processing toolkit for CVI could be used in Visual C++. It is not written to use C++ data types (like CNiVector, etc.) like the Measurement Studio analysis classes are though. Also, you would not have the function panels available in Visual C++. You may want to install CVI and refer to the function panels in CVI for help in using the functions. You would be able to use the library in Visual C++ though.
Best Regards,
Chris Matthews
(2,890 Views)
You can use the signal processing toolkit libraries in VC++, but the libraries do depend on CVI libraries. The easiest way to create a Visual C++ project that links to the CVI libraries would be to either a.) create the project in CVI then convert it using the Measurement Studio CVI conversion wizard, or b.) create a Visual C++ project that uses the CVI libraries with teh Measurement Studio application wizard.
For more information on the conversion wizard, see the following topic in the Measurement Studio references:
(Measurement Studio for Visual C++ 6)
Visual C++ Help\Tutorials\Getting Started\Measurement Studio for Visual C++ 6.0\Converting LabWindows/CVI Projects to Measurement Studio for Visual C++ Projects
(Measurement Studio for Visual C++ .NET)
Visual C++ Help\Tutorials\Getting Started\Measurement Studio 6.0 for Visual C++ .NET\Working with LabWindows/CVI Projects in Visual C++
- Elton
(2,890 Views)
