Measurement Studio for VC++
Program DAQCard-AI-16XE-50 with Measurement studio
Does DAQCard-AI-16XE-50 can works with a application created by Measurement studio? I have developed a data acquisition software base on PCI-MIO-16E-4, but I want swith the card to DAQCard-AI-16XE-50, it likes doesn't work, I don't known why?
(2,976 Views)
That card is much slower (20KHz instead of 250KHz) and has no analog output capabilities. Make sure you aren't trying to go to fast or use analog output. Also, set your program up to check for NI-DAQ error from the functions. The errors returned should tell you information on why your code isn't working.
Best Regards,
Chris Matthews
(2,976 Views)
Have you tested the DAQCard-AI-16XE-50 in MAX (Measurement and Automation eXplorer)? Make sure the card is detected in MAX, and test the AI channels before developping your application.
RamziH.
(2,976 Views)
Thanks lots to Chris and RamziH,
I have tested DAQCard-AI-16XE-50 on Max, it works fine all analog channels, the device nubmer is 1. So, in my program I am using this device number, checking the sample rate no more than 20kHz and no analog output function in my program, but it still doesn't works. Does CWAI works with DAQCard-AI-16XE-50? The DAQ driver version is 6.9.2.
Thanks again.
(2,976 Views)
