Measurement Studio for VC++
NiReport and plotting 2 graphs on the same line
Hi, i'm using NiReport and would like to plot 2 graphs on the same line. (that is, the output should have 2 side by side graphs on the same line) however when i enter the sample code shown below i get graphs on what appear to be separate lines. the graphs themselves are pretty small so, in principle, i figure you ought to be able to do this. can anyone help?
sample code:
CNiReport myreport;
CNiPicture graph1 = m_graph1.ControlImage();
CNiPicture graph2 = m_graph2.ControlImage();
myreport.Body.AppendPicture(graph1,"some caption");
myreport.Body.AppendPicture(graph2,"more captions");
myreport.NewLine(); //skip a line
etc...
report.Print(); //dump to printer
thank you very much,
ken
(2,575 Views)
First, I'm not sure if you meant to do this, but to print the report, you have "report.Print()" instead of "myreport.Print()." That may have just been here, though.
I would play around with the Print function for a while. I don't use it very often, but you might want to try it with different objects and see if it's able to align them properly. Do you know if this happens with other controls than just graphs? Let us know what you find.
J.R. Allen
(2,575 Views)
