As fas as I know I have two copies of the same version of MS6.0. When I bring code in from one copy to the other I get the message
"The Active X Control cannot be instantiated."
I hit OK and it says:
"The Active X Control {bunch of hex values} is not registerd on this computer. Register the control and try again."
If I remove all my cwdiolines and cwdioline and cwdioport and cwdioports stuff and add the control again from the Registered ActivX Controls folder it doesn't help. If I remove any DAQ device I have installed and reboot the computer and then run the program's exe file it works. It's always when I load the project's workspace that I have this problem.
Any info on how to register ActiveX controls without d
oing another reinstall?
Grant
Grant M. Johnson
Project Engineer
LECO Corporation
