I've been "working" with Tek customer support to correct a bug in a TDS series 3000 scope sample application over GPIB. The programming documentation is not sufficient to correct and expand the application to be useful. Note: I am not using VISA.
I am trying to get an entire 500 pt. waveform acquisition that captures either the entire scope "face" or from the trigger to right side of the scope face. Their sample code acquires 250 "valid" (the last 250 are zeroes) samples starting at the center of the scope face. The result is a low resolution representation of half your waveform.
The critical part for me is understanding an exact breakdown of their data format for acquisitions of WIDTH 2. I've
not found this nor found anyone who can pass such a description on.
I appreciate any light you can shed on this problem.
Thanks -- Bill
