04-10-2014 09:07 AM
Hi everyone,
I'd like to know how can I read multiple channels at the same time in VB2010. I'm using an example of NI:
Imports NationalInstruments.DAQmx
Public Class MainForm
Inherits System.Windows.Forms.Form
Private myTask As Task 'A new task is created when the start button is pressed
Private reader As AnalogMultiChannelReader
Private dataColumn As DataColumn() 'Channels of Data
Private dataTable As DataTable = New DataTable 'Table to Display Data
Private Sub startButton_Click_1(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles startButton.Click
startButton.Enabled = False
Try
' Create a new task
myTask = New Task()
' Initialize local variables
Dim sampleRate As Double = Convert.ToDouble(rateNumeric.Value)
Dim rangeMin As Double = Convert.ToDouble(minimumValueNumeric.Value)
Dim rangeMax As Double = Convert.ToDouble(maximumValueNumeric.Value)
Dim samplesPerChan As Int32 = Convert.ToInt32(samplesPerChanNumeric.Value)
' Create a channel
myTask.AIChannels.CreateVoltageChannel(physicalChannelComboBox.Text, "", AITerminalConfiguration.Rse, rangeMin, rangeMax, AIVoltageUnits.Volts)
' Configure timing specs
myTask.Timing.ConfigureSampleClock("", sampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, samplesPerChan)
' Verify the task
myTask.Control(TaskAction.Verify)
reader = New AnalogMultiChannelReader(myTask.Stream)
' Prepare the table for data
InitializeDataTable(myTask.AIChannels, dataTable)
acquisitionDataGrid.DataSource = dataTable
' Read the data
Dim data() As AnalogWaveform(Of Double) = reader.ReadWaveform(samplesPerChan)
dataToDataTable(data, dataTable)
Catch ex As DaqException
MessageBox.Show(ex.Message)
Finally
myTask.Dispose()
startButton.Enabled = True
End Try
End Sub
Private Sub dataToDataTable(ByVal sourceArray As AnalogWaveform(Of Double)(), ByRef dataTable As DataTable)
' Iterate over channels
Dim currentLineIndex As Integer = 0
For Each waveform As AnalogWaveform(Of Double) In sourceArray
Dim dataCount As Integer = 0
If waveform.Samples.Count < 10 Then
dataCount = waveform.Samples.Count
Else
dataCount = 10
End If
For sample As Integer = 0 To (dataCount - 1)
dataTable.Rows(sample)(currentLineIndex) = waveform.Samples(sample).Value
Next
currentLineIndex += 1
Next
End Sub
Public Sub InitializeDataTable(ByVal channelCollection As AIChannelCollection, ByRef data As dataTable)
Dim numOfChannels As Int16 = channelCollection.Count
data.Rows.Clear()
data.Columns.Clear()
dataColumn = New DataColumn(numOfChannels) {}
Dim numOfRows As Int16 = 10
Dim currentChannelIndex As Int16 = 0
Dim currentDataIndex As Int16 = 0
For currentChannelIndex = 0 To (numOfChannels - 1)
dataColumn(currentChannelIndex) = New DataColumn
dataColumn(currentChannelIndex).DataType = System.Type.GetType("System.Double")
dataColumn(currentChannelIndex).ColumnName = channelCollection(currentChannelIndex).PhysicalName
Next
data.Columns.AddRange(dataColumn)
For currentDataIndex = 0 To (numOfRows - 1)
Dim rowArr As Object() = New Object(numOfChannels - 1) {}
data.Rows.Add(rowArr)
Next
End Sub
End Class
