Measurement Studio for VC++
How can I read multiple channels with .NET
Hi everyone,
I'd like to know how can I read multiple channels at the same time in VB2010. I'm using an example of NI:
Imports NationalInstruments.DAQmx
Public Class MainForm
    Inherits System.Windows.Forms.Form
    Private myTask As Task  'A new task is created when the start button is pressed
    Private reader As AnalogMultiChannelReader
    Private dataColumn As DataColumn()             'Channels of Data
    Private dataTable As DataTable = New DataTable 'Table to Display Data
    Private Sub startButton_Click_1(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles startButton.Click
        startButton.Enabled = False
        Try
            ' Create a new task
            myTask = New Task()
            ' Initialize local variables
            Dim sampleRate As Double = Convert.ToDouble(rateNumeric.Value)
            Dim rangeMin As Double = Convert.ToDouble(minimumValueNumeric.Value)
            Dim rangeMax As Double = Convert.ToDouble(maximumValueNumeric.Value)
            Dim samplesPerChan As Int32 = Convert.ToInt32(samplesPerChanNumeric.Value)
            ' Create a channel
            myTask.AIChannels.CreateVoltageChannel(physicalChannelComboBox.Text, "", AITerminalConfiguration.Rse, rangeMin, rangeMax, AIVoltageUnits.Volts)
            ' Configure timing specs
            myTask.Timing.ConfigureSampleClock("", sampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, samplesPerChan)
            ' Verify the task
            myTask.Control(TaskAction.Verify)
            reader = New AnalogMultiChannelReader(myTask.Stream)
            ' Prepare the table for data
            InitializeDataTable(myTask.AIChannels, dataTable)
            acquisitionDataGrid.DataSource = dataTable
            ' Read the data
            Dim data() As AnalogWaveform(Of Double) = reader.ReadWaveform(samplesPerChan)
            dataToDataTable(data, dataTable)
        Catch ex As DaqException
            MessageBox.Show(ex.Message)
        Finally
            myTask.Dispose()
            startButton.Enabled = True
        End Try
    End Sub
    Private Sub dataToDataTable(ByVal sourceArray As AnalogWaveform(Of Double)(), ByRef dataTable As DataTable)
        ' Iterate over channels
        Dim currentLineIndex As Integer = 0
        For Each waveform As AnalogWaveform(Of Double) In sourceArray
            Dim dataCount As Integer = 0
            If waveform.Samples.Count < 10 Then
                dataCount = waveform.Samples.Count
            Else
                dataCount = 10
            End If
            For sample As Integer = 0 To (dataCount - 1)
                dataTable.Rows(sample)(currentLineIndex) = waveform.Samples(sample).Value
            Next
            currentLineIndex += 1
        Next
    End Sub
    Public Sub InitializeDataTable(ByVal channelCollection As AIChannelCollection, ByRef data As dataTable)
        Dim numOfChannels As Int16 = channelCollection.Count
        data.Rows.Clear()
        data.Columns.Clear()
        dataColumn = New DataColumn(numOfChannels) {}
        Dim numOfRows As Int16 = 10
        Dim currentChannelIndex As Int16 = 0
        Dim currentDataIndex As Int16 = 0
        For currentChannelIndex = 0 To (numOfChannels - 1)
            dataColumn(currentChannelIndex) = New DataColumn
            dataColumn(currentChannelIndex).DataType = System.Type.GetType("System.Double")
            dataColumn(currentChannelIndex).ColumnName = channelCollection(currentChannelIndex).PhysicalName
        Next
        data.Columns.AddRange(dataColumn)
        For currentDataIndex = 0 To (numOfRows - 1)
            Dim rowArr As Object() = New Object(numOfChannels - 1) {}
            data.Rows.Add(rowArr)
        Next
    End Sub
End Class
Message 1 of 1
(5,188 Views)
