Measurement Studio for VC++
Get plot cursor position DURING cursor move.
I am using MS 2013 with Vstudio 2010.
During dragging plot cursor by mouse, the current cursor positon is dynamically updated while it is moved.
However, the "scatterGraph.Cursors[0].XPosition" is only updated on event "AfterMove", when cursor is released.
I want to dynamycally change caption of the plot WHILE cursor is moved, like:
private void scatterGraph1_CursorChanged(object sender, EventArgs e) {
scatterGraph.Caption = "X=" + scatterGraph.Cursors[0].XPosition.ToString("#00.0") + ", Y=" + scatterGraph.Cursors[0].YPosition.ToString("0#.0");
During move, this even is fired, but Xposition Yposition do not change until mouse button is released.
I can see dynamic changes on a plot in the small box attached to cursor, however I cannot find a way to extract position of the cursor before mouse is released.
How I can do it?
Thanks, Igor
(3,566 Views)
There is a BeforeMoveCursor event that you can use.  Is it possible to call that and constantly update the position values?  Here's the online documentation on it.
http://zone.ni.com/reference/en-XX/help/375857A-01/html/e_nationalinstruments_ui_windowsforms_xygrap...
(3,525 Views)
Accepted by topic author IgorKord
Thank you,
I made it working, but used AfterMoveCursor event:
private void scatterGraph_AfterMoveCursor(object sender, NationalInstruments.UI.AfterMoveXYCursorEventArgs e) {
     var Xpos = e.Cursor.XPosition;
     var Ypos = e.Cursor.YPosition;
     scatterGraph.Caption = "X=" + Xpos.ToString("#00.0") + ", Y=" + Ypos.ToString("0#.0");
Igor
(3,520 Views)
