Measurement Studio for VC++
Error Code:-86
I have created a CVI project(using NI Measurement Studio AppVizard) in visual C++6.0. This application will load a .uir file "test.h" which was created in CVI6.0. The uir file contains only one button "OK" and the callback function for this button is "OnOK". I have implented the function in file "test.c". I included both "test.h" and "test.c" in the visual c++ project. When I built and run the project, a panel displayed and said:
Error Code: -86
The callback function, OnOK, specified in the UIR file, is
not a known funciton. If you are using an external compiler,
you must include the UIR callbacks object or source file
in the executable or DLL.
I don't know what is the problem.
Could anyone help me?
Thank you very very much.
(2,874 Views)
One possibility could be that you don't have the object file for the callback table in your project. Take a look at the KB article I Get Error -86 When I Try to Use a Static Library Created in CVI. Why? and see if it helps in your case.
- Elton
(2,874 Views)
Thank you so so so much. You are right and now my application works. Thank you again for your answer.
(2,874 Views)
