Measurement Studio for VC++
CNiMath::CrossSpectrum() programming experience?
According to NiMath.h in-line comment, this function "calculates the double-sided cross power spectrum of two time-domain signals." Parameter 1 and 2 are time-domain signals as inputs. Upon return, the third parameter should contain the double-sided cross power spectrum between the two time-domain signals, in a complex form.
Looking at the real part, I am surprised that it contains some negative values. Can "power spectrum" be negative? Would appreciate anyone sharing your experience. Further questions:
1.  Do I need to scale the two time-domain signals?
2.  Why this function does take sampling rate into concern?
3.  There is another similar API, CNiMath::CrossPowerSpectrum(), which takes sampling frequency into account. What are the guideline while comes to decide which API to use?
Thanks again for your generous sharing of programming experience.
(4,869 Views)
Hello year2070,
CrossSpectrum() calculates the doubled-sided cross power spectrum, while CrossPowerSpectrum() calculates the single-sided form. Which you use is dependent on what information you're seeking to obtain. The following document goes into more detail about the differences between the two.
http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/libref/analysisconcepts/cross_power_spect/
(4,856 Views)
