08-19-2013 05:04 AM
I am trying to get dashed grid lines onto my graph. Having searched around, I suspect that I can only achieve this by setting the background as a bitmap that has the dashed lines on. Is this correct?
I think that this was addressed in the .NET version, which now has this functionality, but not in the (legacy) VC++ version. I just wanted to confirm that this was the case.
08-21-2013 10:42 AM
Hi DeltaC,
Could you tell me the exact versions of the measurement studio and visual studio you're using that aren't allowing you this functionality?
Kind regards,
08-21-2013 10:47 AM - edited 08-21-2013 10:50 AM
Hi Matt,
Thanks for the reply. I'm using version 12.0.0.318. The option doesn't appear to be in the property pages.
EDIT: I'm using Visual Studio 2010 version 10.0.30319.1.
08-22-2013 03:01 AM
Actually, the version of MStudio I listed is the one I originally installed, but that didn't come with VC++ or MFC support, so I requested the C++ MFC Legacy Support R2 for Visual Studio 2010 and installed it afterwards.
The About box in the graph property pages says version 8.6.11 Release (465) (602).
08-22-2013 04:46 AM
Hi Richard,
After installing the legacy support version to one of our machines I can confirm that the feature you're looking for does not seem not available for VC++. Unfortunately as this is legacy support it is unlikely the feature will be added in the future.
I hope this answers your question
Kind regards,
08-22-2013 04:49 AM
That's what I suspected.
Thanks, Matt.
