Hi there, i have a problem using MyTask.Timing function.
I would like to know how I can controll the samplerate frequency; while using MyTask i noticed that it doesn't make the expected cycles but only the first.
I can only control the data sampling rate on Matlab with the .Rate option, but i couldn't control it directly using VB.net
Thank You.
Private Sub btSTART_Click(sender As Object, e As EventArgs) Handles btSTART.Click
NC = NumericUpDown1.Value 'numero di cicli
Dim cycleIndex As Integer = 0
If isJustHomed = True Then
xHome = Math.Round(AxMintController1.get_Pos(0) * CConv, 4)
End If
Dim Vel(Ns - 1) As Double
AxMintController1.set_Suspend(0, 0) 'Remove "hold" to the engine
HoldBox.Checked = False
Dim myTask As New Task ' Assign a name to "task"
myTask.AOChannels.CreateVoltageChannel(ComboBoxMo.Text, "MOTOR", Convert.ToDouble(tbminMo.Text), Convert.ToDouble(tbmaxMo.Text), AOVoltageUnits.Volts)
myTask.Timing.ConfigureSampleClock("", TextBox7.Text, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples)
Dim writer As AnalogSingleChannelWriter = New AnalogSingleChannelWriter(myTask.Stream)
Do
For I As Integer = 0 To Ns - 1
Vel(I) = v(I) * kV
Next
'writer.WriteMultiSample(True, Vel) 'synchronous
writer.BeginWriteMultiSample(True, Vel, Nothing, Nothing) 'Asynchronous
myTask.WaitUntilDone()
xStop = Math.Round(AxMintController1.get_Pos(0) * CConv, 4)
NC -= 1
Label3.Text = NC
TextBox11.Text = xStop - xHome
Loop While NC <> 0
