04-14-2016 02:59 PM
I use "windows 8.1, VB6, Measurement & automation" to work for a long time, everything is running well, but my computer broken last mouth,
then I refresh my computer and reinstall all program,
1. install VB6 with windows 8, (upgrade to windows 8.1 2 day late)
2. install NI driver 9.0.2 ( support VB6)
3. install " Measurement Studio 8.1.2 Enterprise Edition for Visual studio 6.0 " from Labview 2010 DS2 DVD ( no install Labview)
the message show "Runtime Error! Program: H:\Distributions\MS_VS6\setup.exe R6025 - pure virtual function call" then exit
I use my software setup file to install & run my software( try register old version to the computer),the .exe file working well,
when I open the software with VB6 to edit, it show cwui error "error loading control. A newer version needed. the default setting for the control will be used."
and CWGraph is 'evaluation copy' ( the other component ex: CWButton,CWNumEdit is OK ), How can I fix? somebody can help?
thanks!
ps: Labview 2010 DS2 DVD not for windows 8 but it's last version with " Measurement Studio 8.1.2 Enterprise Edition for Visual studio 6.0 "
04-15-2016 02:31 PM
I'd guess that your Measurement Studio version isn't compatible with the OS. If you look at the compatibility chart for LabVIEW and Windows, Windows 8 does not support LabVIEW 2010. I would imagine that this also applies to Measurement Studio.
04-15-2016 03:33 PM
Thanks! Dsum
I do same install for the last computer (around 2013) , it working well
any suggest ?!
04-18-2016 05:05 PM
What was the OS on your last computer?
04-19-2016 09:41 AM
same! windows 8 then upgrade to 8.1
04-20-2016 08:15 AM
It seems like your Measurement Studio version is not officially supported on Windows 8 according to this article: http://www.ni.com/mstudio/product-lifecycle/
You could try going through re-install procedures but it seems like the installation behavior will be inconsistent and unreliable. I would suggest an upgrade to your Measurement Studio version.
04-21-2016 12:14 PM
thanks!
look like no Measurement Studio version can match with windows 8.1 & vb6
